Intel® Desktop Boards
Peer-to-peer support only
11429 Discussions
DZ77RE-75K can't boot after BIOS 66
WRide
IT might just be my system, but after the upgrade to the new 066 BIOS, my system won't boot to the desktop unless the BIOS is in it's as installed default state. Hangs @ code C6
Has anyone else experienced problems?
Is it my system, does something actually need to be set to get it to boot?? or something which needs looking with the upgrade?
Thanks in advance
WRide
Well, that was a very exciting adventure just had.... full of the up and downs of a back flash which didn't take, (same condition present... no boot) a Recovery BIOS attempt to the previous release which just sat there and laughed - several times. Doing a Basil Fawlty impersonation at the motherboard brought a moment's joy, as a Recovery attempt to the latest release did work.
Crikey, what happened there?? (was the BIOS really written by a young person who takes her duties of "messing with their heads" very seriously indeed?)
But all to no avail... as settings were applied the $# %$&$!!! failed to boot again. OKayyyyy... deep breath, a nice cup of tea and seeing the cat scurrying out the door in interests its own safety, applied one's self to a step by step/ item by item look see at just what the heck was going on "inside",
Turns the first selection was the culprit... Secondary SATA needs to be engaged for the mobo to boot properly
WHY????? what have we done to deserve this... we've been faithful and easy to get on with customers - haven't we? We've always looked after your products and spread good will - haven't we?
WTF! - WHY????
DArce
Valued Contributor III
So, what you refer to is that the secondary SATA controller in the system needs to be enabled so the system can boot normally?
Is there something connected to the secondary SATA ports (gray ports managed by a Marvell controller) in that system?
WRide
Hi
No, nothing is connected to the grey ports at all and yes, the controller needs to be enable to allow proper booting to the desktop.
I have four ports in use... the two blue, with Intel 520's (ports 0 and 1), an optic drive in port 2 (black) and a WD Red in port 3 (black).
The mobo will beep once and the BIOS splash screen (which used to be the skull) appears, then after a short time it will beep once again then hangs, still at the same splash screen.. If F2 isn't pressed (to gain access to the BIOS itself) within the very few first seconds, there is no access to BIOS.
DArce
Please use the Intel® System Identification Utility using the following site:
http://www.intel.com/support/siu_la.htm?wapkw=%28siu%29 http://www.intel.com/support/siu_la.htm?wapkw=%28siu%29
That will generate an 8 digits code called Report Reference ID. Please let us have that code, this will provide us information on what is being detected on your system. In addition please fill in the following information:
AA number and Serial number of the motherboard:
Processor model:
Memory manufacturer and part number:
Wattage and model of the power supply installed:
WRide
Hi
Thanks for looking into this
Report Reference ID: 0191 8934
AA number and Serial number of the motherboard: G39010-302 / BQRE219000NR
Processor model: i7-3770K
Memory manufacturer and part number: Gskill RipjawsX F3-12800cl9Q-16GBXL
Wattage and model of the power supply installed: 860w Corsair AX860
DArce
I wanted to let you know that I was able to replicate this behavior, so let me forward this to the research team so a fix may be provided in a next BIOS release.
Thank you for bringing this up. We really appreciate this kind of feedback.
WRide
Thanks, Diego, for looking into this... it is much appreciated
Cheers
