Intel® Desktop Boards
Peer-to-peer support only
11479 Discussions
DZ77RE-75K show only 4GB memory
hatta
i have
Windows 7 Ultimate x64
Intel DZ77RE-75K (BIOS 66 latest)
Core i5-3450
Corsair 12GB (3x4GB) 1600MHz 9-9-9-24 1.50V
it shows on bios and windows 7 that i have 4GB memory only
Can anyone help me?
hatta
NO ONE CAN HELP ME !!!!!
Silvia_L_Intel1
Hamood_d10, please let me know if this is new integration or if this behavior started recently?
If you restart the system without memory, are you getting 3 beeps?
Please keep in mind the blue DIMMs needs to be populated first. Would you please test one memory stick at the time on each blue DIMM, restart the system and check if it is being recognized? I just want to find out if there is a defective slot on the board.
Then, if you are able to boot using 1 memory stick, please add a second one using only the blue DIMMs. If both memory sticks work fine, try to clear the settings on the BIOS taking the battery out for 5 minutes then put it back in the same position, boot to the BIOS and set the data and time and give it a try with both memory sticks.
