Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
DZ77RE-75K - voltage regulator status LEDs
Community Manager
I recently bought a DZ77RE-75K MB and assembled a computer.
I see that the voltage regulator status LEDs are green and cycling (all LEDs come On and one by one goes off) in a series all the time.
Is this normal?
MB: DZ77RE-75K
CPU: core i7 3770K
Memory: 16GB Corsair Vengeance 1600MHz
HD: Samsung 840 series 256 GB SSD
PSU: Ultra 850W
RRamo7
New Contributor III
Hi Rao V,
This is totally normal, all the lights goes on and then one by one goes off in a series, it is supposed to work in that way.
Below you can read a brief description of how it works:
The VR status LEDs provide a real-time indication of how many processor VR phases are active. During normal system operation the power requirements of the processor can vary due to its power saving features. When the processor is in a low-power or idle state it requires less power to be provided by the VR. The VR responds to the lower power demand by shutting down unneeded phases thereby increasing overall power efficiency. Each VR phase has an LED connected to it that indicates when that phase is active.
RRamo7
New Contributor III
Hi Rao V,
Community Manager
Thank You.
JMore8
On my DZ77BH-55K the Voltage Regulator (VR) Status LEDs flash all on, then all off then all on and then all off, and have no video. Any ideas as to what that means if the Voltage Keeps flashing like that?
Silvia_L_Intel1
Hello Super_Bark,
Since we don't know which device is causing this behavior, these are my recommendation:
  1. Please proceed to test the motherboard with minimal configuration but out of the chassis to discard any grounding issue. (Motherboard, processor, power supply). No memory, no video card, no hard drives.Since we do not have memory installed, you are going to heard 3 beeps.
  2. Place 1 memory stick on DIMM # 1. There should be no beeps and if you press F2, you should be able to go to the BIOS.
  3. Remove the CMOS battery and leave the system without it for about an hour. Then put it back on and restart the system. http://www.intel.com/support/motherboards/desktop/sb/CS-028780.htm?wapkw=clear+cmos+battery# datetime http://www.intel.com/support/motherboards/desktop/sb/CS-028780.htm?wapkw=clear+cmos+battery# datetime
  4. If you went to the BIOS please, shut down the system, add another stick of memory and the hard drive where the operating system was install.
**While performing this troubleshooting check if the light is on or not.**
If you continue having the same behavior, feel free to contact your local support group for assistance: http://www.intel.com/p/en_US/support/contactsupport?group=processor http://www.intel.com/p/en_US/support/contactsupport?group=processor
