Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
DZ77RE-75k Ram problems
Hey.
I just bought DZ77RE-75k for some days ago. When i went to the BIOS to change some Things incl. Ram speed. I set the rams to 1600 MHz from 1333 MHz. but when i rebooted, there came 3 Beeps which Means memory problem. i have tried lots of Things to get them to run at 1600 MHz but it keeps beeping, there is no problem when they run at 1333 MHz.
Computer Specs:
Intel Core I7 3770k
Intel DZ77RE-75K
Corsair Vengeance 16 GB 1600 MHz
Does anybody know what the problem is.
VDerk
New Contributor III
Which BIOS revision?
How many DIMM modules? Does 1600 works with only 2 installed?
Did you select 1600 with menu or used XMS option?
KNoro
Is the ram voltage set to 1.5v when you up the speed to 1600Mhz.If not try 1600Mhz@1.5v
RGiff
Honored Contributor I
Crucial Recommends using 1.35 volt Ram with this board , Check their web site it comes in several varieties . With your CPU and this Board you do not want 1.5 Volt RAM.
Community Manager
I tried to set the Ram speed to 1600 Mhz and 1.5 V but theres still 3 beeps
