After an update from 0039 to 0042 the board did not pass the POST anymore. I disconnected all unnecessary hardware, reseated memory, with no success. No chance to enter the firmware settings. Port 80h code before restarting was E6.
After a recovery BIOS downgrade to 0039 everything was fine.
So what is the problem? Buggy BIOS? Hardware failure?
Obcy, thanks a lot for sharing your experience with us. I already reported this situation to the corresponding department in order to check if there is a bug on this BIOS version.
In the mean time, please keep your system with BIOS v0039.
I am also running 0042, didn't see the problem (but the DZ68BC bios quality has been not that good). 0042 resolved my problem with the "unsupported CPU screen" at startup. The only other main new feature in 0042 is a firmware upgrade for several CPU types. Which specific hardware do you have (board revision, CPU, memory type)?
Removing some memory banks temporarily may trigger a new initialization that can solve the problem, I have used this in the past when DZ68BC goes in 'restart' mode (actually seen once with 0042).
My best results are also by using the F7 bios update. To be sure you could download 0042 again to ensure the file was not corrupted during the download.
My impression (based on the history of DZ68BC bios releases) is however that something was broken in 0042 that is only triggered on your motherboard revision+CPU+memory-type combination+psu.
I am having the same issue! Frustrating.
DZ68BC
I7-3770S (had same issue with i3-2120)
16 GB PNY DDR3-1600
Gurgi63, I'm sorry for the inconvenience that you have faced with your motherboard. Would you please provide some important information?
Which is the current BIOS version on your board?
Which is the AA# of your motherboard?
Would you please describe the behavior of your system? Are you getting beeps?
Current bios as of 3/4/2014: 0039
AA# G30472-402
No beeps, just displays Intel splash screen then reboots, it won't even allow you to access the bios.
Giurgiu 63, would you please test your system out of the chassis? This in order to discard any grounding to the board
You said that you have the same behavior when using a 2nd generation processor like the I3-2120, correct?
Have you ever used this system or it has never worked since you purchased it?
I had problems from the beginning because I was using an i5 processor and the bios (0028) apparently didn't support it. The board would give the three beeps of a memory error. After I tried the i3 processor it booted but wouldn't take a bios update until I updated to 0029 then it let me update to 0036 and when it wouldn't take 0042 I loaded 0039. I loaded all bios updates outside of the case since I had been having issues with the board. I didn't install the board in the case until it posted with the i5-3770s. Even after loading windows the board won't take bios 0042 from windows or boot to usb flash drive.
Gurgi63, could you please send me a private message letting me know where are you located?
Could you also include your personal information?
I too am having this issue. I am using the i7-2600K processor and was getting the notification about using an invalid processor after the update to BIOS 39. Although the error message is now gone, the machine will reboot typically three times before it will boot into Windows. Each time it boots, the system will go all the way through the MARVELL controller posts and then after the 2nd controller posts on the screen, the machine will shut itself down and start again. It will go through this twice, and then finally reboot into windows.
I am using board AA-G30742-401.
I tried flashing back to bios 0039, and then windows ceases to function after approximately 5 minutes. I'm currently using bios 0042 and its stable once running, but the rebooting thing needs to be corrected.
I have two Seagate ST3000DM001 drives connected to the Marvell controller (light blue) in a RAID1 configuration
I have a Corsair Force GT SSD drive connected to the PCH controller (blue)
and I have a Seagate ST31500541AS drive connected to the PCH controller (black)
I have the same configuration (i7-2600K, AA-G30742-401, BIOS 0042) but not seen that kind of problems. I do have the MARVELL controller disabled (it is slow anyway, compared to the PCH) in the BIOS.
My AA-G30742-401 is a replacement board however, I did see restarts like this with my original board and older versions of the BIOS. You could check if your board is still under warranty.
in order to find out is you board is still under warranty It will be necessary to check the markings of the board, so would you please send me a private message with the AA# and the serial number?
This information is going to be located at the motherboard itself, on a white sticker label close to the memory slots
@arhame, could you also send me the markings thought a private message?
My Nephew has a DZ68BC just upgraded to BIOS 86A.0042.2013.0902.1038 and he is experiencing system hang ups. cycling through posts at startup. Anyone have any suggestions?
[System Summary]
Item Value
OS Name Microsoft Windows 7 Ultimate Edition x64
OS Version 6.1 Service Pack 1 (Build 7601)
System Name PC
System Model DZ68BC__
System Manufacturer INTEL_
Processor Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
BIOS Version INTEL - 1072009
IP 192.168.1.146
Windows Directory C:\Windows
System Directory C:\Windows\system32
Locale United States
User Name Mike
Time Zone Eastern Standard Time
Total Physical Memory 16361 MB
Available Physical Memory 9844 MB
[Devices]
Device Name Device Type
Disk drive DiskDrive
Terminal Server Mouse Driver System
Marvell 91xx Config Device Driver LegacyDriver
Microsoft Bluetooth Enumerator Bluetooth
Microsoft ISATAP Adapter Net
NVIDIA High Definition Audio MEDIA
Generic USB Hub USB
Generic volume Volume
Security Driver LegacyDriver
HID-compliant consumer control device HIDClass
Plug and Play Software Device Enumerator System
NAVENG LegacyDriver
System Attribute Cache LegacyDriver
VgaSave LegacyDriver
Bluetooth Device (Personal Area Network) Net
Bitlocker Drive Encryption Filter Driver LegacyDriver
NVIDIA GeForce GTX 550 Ti Display
SM-G900V WPD
USB Input Device HIDClass
UMBus Enumerator System
Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 1 - 1C10 System
Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C2D USB
UMBus Root Bus Enumerator System
Security Processor Loader Driver LegacyDriver
Microsoft Teredo Tunneling Adapter Net
Generic USB Hub USB
Motherboard resources System
Intel Processor Processor
NAVEX15 LegacyDriver
LDDM Graphics Subsystem LegacyDriver
Microsoft Virtual Drive Enumerator Driver System
Dynamic Volume Manager LegacyDriver
HTTP LegacyDriver
Bluetooth Device (RFCOMM Protocol TDI) Net
ACPI x64-based PC Computer
STORAGE DEVICE-6 WPD
Volume Manager System
NDIS System Driver LegacyDriver
Hardware Policy Driver LegacyDriver
Symantec Eraser Control driver LegacyDriver
File as Volume Driver System
Storage volumes LegacyDriver
Brother MFC-7840W Printer Printer
Symantec Real Time Storage Protection (PEL) x64 LegacyDriver
PCI standard PCI-to-PCI bridge System
Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 4 - 1C16 System
Intel(R) Management Engine Interface System
USB Composite Device USB
NDProxy LegacyDriver
Composite Bus Enumerator System
Programmable interrupt controller System
Efi Invoker Service LegacyDriver
IDSVia64 LegacyDriver
Remote Access IPv6 ARP Driver LegacyDriver
ACPI Fixed Feature Button System
HID-compliant device HIDClass
adfs LegacyDriver
Generic PnP Monitor Monitor
System timer System
KSecDD LegacyDriver
Kernel Mode Driver Frameworks service LegacyDriver
USB Mass Storage Device USB
USB Printing Support USB
USB Root Hub USB
Ancillary Function Driver for Winsock LegacyDriver
WD SES Device WDC_SAM
NETBT LegacyDriver
Marvell 91xx SATA 6G Controller SCSIAdapter
High precision event timer System
Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 5 - 1C18 System
Realtek High Definition Audio MEDIA
KSecPkg LegacyDriver
Intel(R) Z68 Express Chipset Family LPC Interface Controller - 1C44 System
Generic volume shadow copy VolumeSnapshot
WFP Lightweight Filter LegacyDriver
IDE Channel LegacyDriver
802.11 n WLAN
USB Root Hub USB
Direct memory access controller System
Brother MFC-7840W Image
lirsgt LegacyDriver
User Mode Driver Frameworks Platform Driver LegacyDriver
Renesas Electronics USB 3.0 Root Hub USB
atksgt LegacyDriver
Generic Bluetooth Adapter Bluetooth
NSI proxy service driver. LegacyDriver
Disk Virtual Machine Bus Acceleration Filter Driver LegacyDriver
Communications Port Ports
Link-Layer Topology Discovery Mapper I/O Driver LegacyDriver
Microsoft System Management BIOS Driver System
Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 7 - 1C1C System
IDE Channel hdc
Beep LegacyDriver
Microsoft Wireless Router Module Network Infrastructure Devices
System speaker System
Brother MFC-7840W Remote Setup Port Ports
WAN Miniport (IKEv2) Net
Symantec Data Store LegacyDriver
BHDrvx64 LegacyDriver
Null LegacyDriver
IDE Channel hdc
PCI bus System
Renesas Electronics USB 3.0 Host Controller USB
Mount Point Manager LegacyDriver
Marvell 91xx Config Device System
WAN Miniport (L2TP) Net
System CMOS/real time clock System
Microsoft USB Basic Optical Mouse v2.0 (Mouse and Keyboard Center) Mouse
pciide LegacyDriver
2nd Generation Intel(R) Core(TM) Processor Family DRAM Controller - 0100 System
Microsoft Hardware USB Mouse HIDClass
Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 8 - 1C1E System
SymEvent LegacyDriver
IDE Channel hdc
Windows Firewall Authorization Driver LegacyDriver
WAN Miniport (Network Monitor) Net
System board System
Performance Counters for Wind...
Hello Morty61, would you please try rolling back to BIOS version 0039 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22159 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22159
Please use the BIOS recovery method http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm
I am also facing the same problem of continuous restarting of system after updating bios to 0042 from 0039 ?????, Must I roll back ? On bios 0039 ? " Not compitable " boot logo is always headache on bios 0039.
CPU- i5-3570k
RAM- Corsair Ven. DDR3-1600Mhz ,8 GB
Please suggest soluation
