Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
DZ87KLT-75K BIOS UPDATE for Upcoming 5th Gen CPU Broadwell ? & Windows 10 Driver Support?
Stephen
Valued Contributor I
It's all over the internet that Broadwell will be launching some time in June of this year and it will reportedly launch only two 1150 CPUs all Unlocked namely Core i7-5775C and the Core i5-5675C this are 14nm parts.
Both the i7-5775C and the i5-5675C are quad-core parts, with TDP rated as low as 65W. The i7-5775C offers clock speeds of 3.30 GHz, with 3.70 GHz Turbo Boost, while the i5-5675C offers 3.10 GHz, with 3.60 GHz Turbo Boost. The i7-5775C comes with just 6 MB of L3 cache, while the i5-5675C offers just 4 MB of it. The i7-5775C offers HyperThreading, letting the OS address eight logical CPUs, while the i5-5675C lacks it. Both chips feature Intel's Iris Pro 6200 series integrated graphics, and feature dual-channel DDR3L-1600 memory support.
This will be good for the DZ87KLT-75K as its the last Intel Desktop Board plus the above mentioned CPUs will be the last of 1150 socket, If Intel could spare some time and update the DZ87KLT-75K's BIOS to at list support the Broadwell 14nm. Intel refused to support Haswell Refresh as far as we've seen. Maybe Since broadwell seems to make much of an upgrade sense in terms of power consumption and optical shrink it would be nice to have support for the upcoming two chips.
Windows 10
I hope we will not be left behind support wise in regards to Windows 10 drivers for DZ87KLT-75K when the operating system launches its the next big thing coming out and supports DX12, Intel please consider.
Stephen B.R.
Jose_H_Intel1
Let me check about the driver support for Windows* 10.
Processor compatibility will remain the same.
Stephen
Hopefully Intel will start releasing the Windows 10 drivers soon or at list latest when Windows 10 releases, and the board still requires some BIOS updates to fix issues with BIOS not showing up on some monitors or while using displayport inputs and also some memory compatibility increasing and stability which should include quick post from cold boot even while using XMP settings and all four DIMMs populated
Hans_B_Intel
Hello stephenb.b.r,
I just wanted to let you know that since Intel is no longer making motherboards, there are no plans to provide Windows 10* drivers for any of the Desktop Boards.
