Community
cancel
Showing results for
Search instead for
Did you mean:
WBard1
DZ87KLT-75K - bios does not distinguish between disks
DZ87KLT-75K - bios does not distinguish between disks.
Bios shows too little information about disks. If we have three identical drives that do not know how to determine botting.
Is there a chance that fixed this problem?
Miguel_C_Old
The operating system is saved only in 1 Hard Disk Drive unless you create a RAID volume. From BIOS the computer shows you which SATA port is using each Hard Disk Drive. Intel recommends to connect the Hard Disk Drive with the operating system to SATA port 0 always.
BIOS tells you which SATA port contains the hard disk drive with the operating system.
WBard1
mike_intel is right.
You can set the disk to boot from any SATA port connection: PORT0 ..., SATA:PORT1: ... SATA:PORT2: ... SATA:PORT3 ...
It is not necessary to use the extended drive name.
