Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11359 Discussions
DZ87KLT-75k - USB3 front panel issue
KBenm
I am running Windows 7 64bit on a DZ87KLT-75k / 4770 system.
When plugging an USB device (external hard drive, USB stick, etc...) to either one of the front panel USB 3 ports, the devices are not recognized correctly in Windows. The devices appear in explorer, are read and write accessible, however, the "Safely remove hardware" notification doesn't show, there is no "right click -> eject" option in explorer, and the Hardware "Policies" tab (to optimize for either quick removal or performance) is missing.
This is not the case when plugging to the front panel USB 2 ports, or the back panel USB 3 ports. I have tried with both USB 2 and 3 capable devices and cables.
I am using the 2.5.1.28 USB 3 driver, the problem was also occurring with the previous driver version. Forcing the list of plugged devices to show up using "rundll32 shell32.dll,Control_RunDLL hotplug.dll" also doesn't work. Well it works, but the drives are not listed if plugged in the front panel USB 3 ports.
Could this be due to a driver or hardware problem?
Allan_J_Intel1
As you mentioned, this could be a software or hardware issue. In order to test your computer hardware will be to try another USB front panel, if this fails, I am afraid your motherboard requires service.
I recommend, contacting support lines at Intel.
Live Chat support at wwww.intel.com/chat and choose desktop boards line
Allan.
KBenm
Unfortunately there is only one front panel USB3 on the board. The 2.0 one I am using is fine.
Is there a known issue with the drivers maybe?
Allan_J_Intel1
I am not aware of any issues with front panel and USB 3.0 ports. Try updating computer BIOS or wait for new drivers to see if this will be corrected.
Allan.
