Intel® Desktop Boards
Peer-to-peer support only
11480 Discussions
De quelle facons mettre les memoires RAM dans un NUC Kit connecteur du bas prend quel Ram en Gb plus haut ou plus bas en Ram soit 2Gb ou 4Gb
apuch
n_scott_pearson
Super User Retired Employee
I am not sure that I understand your question. My high-school French fails me (it's been over 40 years since I graduated from high school) and the french-to-english translator is mangling the translation pretty badly...
It is recommended that, if you are going to use two SODIMMs in a NUC, these SODIMMs should be the same size (same number of GBs) and have the same specification (operating speed, wait-states, etc.). Matched-pair SODIMMs (i.e. two SODIMMs that come in the same package and which have been tested together) are the best choice...
Hope this helps,
n_scott_pearson
Hope this helps,
apuch
Thank you very much !
I buy a new NUC5CPYH and do you known if we have to close it by the top switch when we dont use it.
n_scott_pearson
You can have your (Windows, Linux, etc.) O/S put it to sleep or power down the system. You can also request a shutdown by pressing the power button.
Community Manager
Thank you Scott for sharing this information for us, I hope this can be useful information for cristalain.
cristalain as N. Scott Pearson has mentioned if you are not using the NUC you can put it to sleep or you can power it down.
Ivan.
