Intel® Desktop Boards
Peer-to-peer support only
11435 Discussions
Desktop Board DH67BL compatible with KVR16R11S4/8KF ?
ACirm
I have a Desktop Board DH67BL (https://ark.intel.com/products/50098/Intel-Desktop-Board-DH67BL Intel® Desktop Board DH67BL Product Specifications )
I received 2x memory modules this model > KVR16R11S4/8KF (https://www.kingston.com/datasheets/KVR16R11S4_8KF.pdf https://www.kingston.com/datasheets/KVR16R11S4_8KF.pdf )
When I put them in they are not detected in bios. I'm not a tech guy so here are my questions:
- I guess it doesn't work because DDR3- 1600 is out of range of motherboard. Is that right ? Some details will be appreciated
- Is there anything I can do to "fix it" ? (eg bios update) or is a hardware limitation and nothing can be done ?
Thank you,
Adrian
LeonWaksman
Here you have list of the compatible memory: https://www.intel.com/content/www/us/en/support/articles/000006556/boards-and-kits/desktop-boards.ht... System Memory for the Intel® Desktop Board DH67BL
The memory you have is incompatible because of two reasons: frequency and module density as well (See the supported memory configurations).
Leon
LeonWaksman
Leon
n_scott_pearson
Super User Retired Employee
Actually, more than that. These are Registered ECC DIMMs. This board only supports Unregistered Non-ECC DIMMs.
ACirm
Thank you bouth,
Unfortunatly I can only mark just one right answer
n_scott_pearson
That's ok; Leon needs the positive reinforcement!
