Intel® Desktop Boards
Peer-to-peer support only
11475 Discussions
Desktop Board DH87RL forgot 2x12 connector: P PWR Falul LED
MMass6
Desktop Board DH87RL, I connect the board the to the power supply but I forgot to connect the 2x12 connector , the board don't start and only the led R Enhanced Standby Led was on, than I verify my error and, after I have disconnect the power, I reconnected all the connectors (2x12 and 2x2), now the led R is on, but the P PWR FAUL LED is on also and only a normal beep is emitted.
Allan_J_Intel1
You could try removing the RAM and see if the board beeps three times. This will let you know if the board and processor are communicating each other.
I recommend checking the following link for tips about this issue:
http://www.intel.com/support/motherboards/desktop/sb/CS-010254.htm Desktop Boards — Troubleshooting System No Boot Issues
If you still have same problem, I recommend contacting Intel Customer Support for warranty options:
http://www.intel.com/p/en_US/support/contactsupport Contact Support
Allan.
Allan_J_Intel1
Were you able to speak with Intel support from the link I have posted?
Allan.
