Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
Desktop Board DX58SO
Community Manager
My motherboard did not come with power connector 12V 4pin. is that right?
JBish3
New Contributor II
Hi Luizhpalacio,
The board has the following power supply connectors:
• Main power – a 2 x 12 connector. This connector is compatible with 2 x 10 connectors previously used on Intel Desktop boards. The board supports the use of ATX12V power supplies with either 2 x 10 or 2 x 12 main power cables. When using a power supply with a 2 x 10 main power cable, attach that cable on the rightmost pins of the main power connector, leaving pins 11, 12, 23, and 24 unconnected.
Note : data taken from TPS
For more info download TPS from here http://downloadmirror.intel.com/18128/eng/DX58SO_TechProdSpec.pdf http://downloadmirror.intel.com/18128/eng/DX58SO_TechProdSpec.pdf
& check page no. 43-44
J.Bisht
