Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
Desktop Motherboard
I have a DQ35JOE motherboard, what newer board is compatible.
Highlighted
Community Manager
In order to find out which board will be compatible, you would need to find out which is the processor you have installed. Each motherboard will have its own compatibility list for supported processors; therefore, if you are not planning to change the processor, you may want to search for compatible boards according to the processor model number, at the following site: http://processormatch.intel.com/ http://processormatch.intel.com/
If you are planning to completely change your system, then the following site will help you out in regards to guidance on which platform is the one that will better meet your needs: http://www.intel.com/consumer/products/processors/comparison.htm?iid=subhdr+learn_proc http://www.intel.com/consumer/products/processors/comparison.htm?iid=subhdr+learn_proc
More information on Intel® motherboards and processors can be found here: http://ark.intel.com/ http://ark.intel.com/
Also, by filtering under "Browse for Product Support" you will be able to enter into the Main Product Support site with all technical resources available for the board in question: http://www.intel.com/p/en_US/support?iid=gg_support-en_US+home_support http://www.intel.com/p/en_US/support?iid=gg_support-en_US+home_support
