Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
Desktop board DQ965ss / DG965GF
SLesa
Desktop board DQ965ss / DG965GF has a red light when switched on. Can anyone help. Remember, no display, but the CPU fan turns on.
Kevin_M_Intel
As per the motherboard Technical Product Specification, the red light located near the memory slots, will be lit if the memory slots are powered.
As part of troubleshooting steps, I recommend you testing other monitor with different cable and make sure cable is not loose.
Also, you can try taking the motherboard outside of the chassis to discard grounding issues. Testing other hardware on the motherboard such as processor or other memory part number may do the trick.
Kevin M
