Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
Dg35ec motherboard with core 2 duo
kkris7
Dg35ec motherboard.
I bought new Two 2gb ram. i already have Two 2gb ram installed.
once install new Two 2gb ram, computer becomes too slow.
i have 4 slot. ( 2gb+ 2gb + 2gb + 2gb ) so it is max 8gb for this motherboard.
after i remove new Two 2gb ram .
computer is faster. loading bios faster, login screen comes faster.
i upgraded in order to get good speed. also i use Photoshop. it needs 8 GB ram in order to work in 3d designs. rendering edit movies.
please some help me. hopefully waiting.
I also have the same problem. system is slow when i install graphic card. after i remove it. computer is fast.
Asus GeForce GT 610 Silent Nvidia
C drive has 50gb free space. out of 110 gb.
System ManufacturerINTEL_System ModelECG3510MSystem Typex64-based PCProcessorIntel(R) Core(TM)2 Duo CPU E7200 @ 2.53GHz, 2527 Mhz, 2 Core(s), 2 Logical Processor(s)BIOS Version/DateIntel Corp. ECG3510M.86A.0118.2010.0113.1426, 1/13/2010SMBIOS Version2.4Windows DirectoryC:\WindowsSystem DirectoryC:\Windows\system32Boot Device\Device\HarddiskVolume3LocaleHardware Abstraction LayerVersion = "6.1.7601.17514"User NameTime ZoneInstalled Physical Memory (RAM)4.00 GBTotal Physical Memory3.99 GBAvailable Physical Memory2.25 GBTotal Virtual Memory7.98 GBAvailable Virtual Memory5.69 GBPage File Space3.99 GBPage Filez
AlHill
You have not provided the type of memory you are using.
Review Section 1.5 on page 16 of https://www.intel.com/Assets/PDF/prodspec/DG35EC-tps.pdf https://www.intel.com/Assets/PDF/prodspec/DG35EC-tps.pdf
Make certain that your memory complies with this specification. Also, view tested memory:
https://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000006758.html System Memory for the Intel® Desktop Board DG35EC
Also, just because you have 8gh of memory does not mean 8gb will be available to Adobe.
Regarding your video card, it is very likely that your GT610 is not fully backward compatible with the PCIe x16 slot.
You did not specify what OS you are running. On this board, nothing above Windows 7 is supported:
https://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000005640.html Supported Operating Systems for Intel® Desktop Boards
This also means that the onboard graphics are not supported, in case you want to use that with Windows 10:
https://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html Supported Operating Systems for Intel® Graphics Products
And, of course, your processor will not be supported on Windows 10:
https://www.intel.com/content/www/us/en/support/processors/000006105.html Intel® Processor Support for Microsoft Windows® 10
This is your board: http://ark.intel.com/products/34689/Intel-Desktop-Board-DG35EC Intel® Desktop Board DG35EC Product Specifications
On a board this old, in my opinion, it is time to take it to a recycle facility and get rid of it. Purchase a new board (which means new memory, processor, power supply, and associated components). You can possibly keep your GT610.
Lastly, support for this board has ended.
https://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/legacy-intel-desktop-... Support for Intel® Desktop Board DG35EC
Doc
kkris7
kkris7
kkris7
AlHill
What is the EXACT model number of the memory you are trying to add?
Doc
kkris7
where can i find model number.
do you mean RAM.
AlHill
Memory, RAM, a rose by any other name...
Look on the physical memory, or on the packaging it came in when you purchased it.
Did you purchase the memory new or used?
Doc
kkris7
kkris7
its a new RAM i purchased
AlHill
I am unable to find specific information on this memory.
I would try different memory. Make certain it matches the specifications provided in the tech spec.
Doc
kkris7
if you wish i can provide any additional info.
some one need to please help me.
im very sad.
AlHill
Try different memory, preferably memory in the tested memory list.
Doc
kkris7
where can i find.
AlHill
Community Manager
Hello Kris32,
This seems to be a compatibility issue with the RAM; I would suggest trying one of the RAMs from the tested memory list.
Ivan U.
