Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
Does not display for the fist time when powered on
RN
I am system integrator, i am facing problem with Desktop board DB85FL with Core I7 4770. When i power on the system fist time i don't get display,
after i remove & put the power cord again & power it on, it is normal for the whole day: irrelevant of how many times turned off & on. I am using Transcend
Ram (1600Mhz, (2R/512Mx8/CL11) 8GB * 2. I had sold the Same configuration a couple of months back, the same problem persists in that also. I have
tried changing the SMPS & also I have ungraded the BIOS, but the same problem persists.
Kevin_M_Intel
Hello Ram_N,
This behavior you are describing is very strange since I have not been able to reproduce it with the same model.
Please try with different monitors and different cables (better quality). Try connecting just one memory stick to the motherboard. Perhaps taking the motherboard outside of the chassis to avoid grounding can do the trick.
Kevin M
LVilc
si tienes 2 memorias ram, prueba desconectando una y solo la dejas funcionando con una.
si el problema persiste has lo contrario quita la que tenias instalada y coloca que que habías quitado anteriormente.
prueba con otro monitor o prueba con otro cable vga y cable de poder del monitor
LVilc
prueba quitando la pila de bios y presiona el boton de encendido por 5 segundos, luego vuelve a colocar la pila de bios y checa si funciona.
si tienes un adaptador de dvi o hdvi a vga prueba conectándola a tu monitor.
o prueba con otra memoria ram nueva.
