Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Driver Problem
Jump to solution
My desktop pc has an Intel DQ35JO AAD82085-800 main board. Operating system now is Windows 10 pro, but cannot do the upgrade because of driver issue as you can see on attached screenshot of the 'Device manager'. The only devices attached to the pc are keyboard and mouse, display, loudspeakers, and a scanner, that's all.
So I would like you to help me solve this driver problem. Ran as well the Intel tool, see attached results.
This is my only pc, I have installed MS Office and some other programs. Do not have the efforts to start right now with a new pc.
Answers will be appreciated.
Motim
Tags (1)
Accepted Solutions
Highlighted
Your board is not supported on Windows 10.
Your missing device is the Intel Management Engine, which you do not need.
It is not surprising that the Intel Driver Update Utility did not find any drivers, so do not be alarmed by that.
What drivers there are for your board can be found here:
https://downloadcenter.intel.com/product/50382/Intel-Desktop-Board-DQ35JO Downloads for Intel® Desktop Board DQ35JO
Doc
Highlighted
Doc
