Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11361 Discussions
Driver failes to install with ME 8.1.10.1300
KAlla1
I have system device driver that will not install and when done trying I get an error massage
Jose_H_Intel1
Hello kqr,
Our best suggestion in this case is to get the drivers from the system manufacturer (O.E.M.) since they may be custom made for your specific model.
KAlla1
I would say by default the computer know if it can install a driver that was not meant for it,
(fyi) ME 8.1.10.1300 is by intel and for this board
and I have O.E.M drivers that do not know their location why is that?
Jose_H_Intel1
Could you provide more specific information about your system such as brand, model and operating system?
Did this driver work before? If so, what changed?
If the same happens with other drivers it could mean the issue is related to the operating system. Have you tried reinstalling it?
KAlla1
Iam running a dx79si with windows8 pro 64 bit
I had an issue were as I had an unkown pci divice with a yellow driver,
Were as I was told too install ME 8.1.10.1300 and that took care of the yellow driver
when I used the mother board install cd for dx79si I got a message install Sequence did
not run.
So at this time I have now yellow drivers, Just this error with ME 8.1.10.1300
and the just the fact I want to install driver locations and I have tried reinstalling ME 8.1.10.1300
Jose_H_Intel1
Kqr, the drivers from the included installation disc may be older and probably not compatible with Windows* 8. In this case try the latest drivers from https://downloadcenter.intel.com/default.aspx Intel Download Center for your specific motherboard and operating system.
It may be also possible that you will need to reinstall the operating system or update the BIOS. However, just go ahead and try with the newest drivers first.
Actually, the latest ME driver for your motherboard is located here. Make sure the chipset driver is installed first.
KAlla1
OK the next I do a reinstall Ill do that any advice on what a
not run,really is
