I have 2 boards in the E210882 group of mother boards. Using Article ID:5624 in the support site one board has AA C64123-302 and is found under: Intel 915 Express Chipset Family Boards with a link toD915AGL(10/100 LAN). The second board has an AA number C87709-303 but isn't in any of the pull-down lists. These two boards have the same artwork some features are supported on one board like the Black JBC1 connector is on C64123 but not on C87709. I simply wanted the manuals and drivers for C87709. Since there is a white sticker over the suppost artwork printed area where D915GAG/D915PSY is written I'm not sure of the chip set group supported. the sticker has: (GW) 152151546BQ01550. The normal AA sticker is: BQAG54602114 AA C87709-303. I assume the GW sticker means computer manufacture that is using this board. Any help would be great I want to confirm the limits of this board.
- Tags:
- E210882
Both of these numbers are for D915GAG/D915GAV boards, one an Intel Desktop Board product and one a board Intel produced for E-Machines. Since the Windows O/S editions supported by these boards are no longer supported, the drivers that were required to support them are no longer supported or available either. We are talking boards released in 2004 after all.
Documentation for these boards is available here: https://www.intel.com/content/www/us/en/support/articles/000021728/boards-and-kits/desktop-boards.ht... and here: https://www.intel.com/content/www/us/en/support/articles/000021721/boards-and-kits/desktop-boards.ht....
Capabilities are summarized here:
Form Factor:
- D915GAV: ATX (12.00 inches by 9.60 inches [304.80 millimeters by 243.84 millimeters])
- D915GAG: microATX Form Factor (9.60 inches by 9.60 inches [243.84 millimeters by 243.84 millimeters])
Processor Support:
- Intel® Pentium® 4 processor in an LGA775 socket with an 800 or 533 MHz system bus
Memory:
- Four DDR SDRAM Dual Inline Memory Module (DIMM) sockets
- Support for DDR 400 MHz and DDR 333 MHz DIMMs
- Support for up to 4 GB of system memory
Intel® 915G Chipset (Intel® 82915G Graphics Memory Controller Hub (GMCH) and Intel® 82801FB I/O Controller Hub (ICH6)):
- 4 Mbit Firmware Hub (FWH)
- Video Intel® GMA900 onboard graphics subsystem
- Audio Intel® High Definition Audio subsystem using the Realtek ALC860 audio codec
- I/O Control LPC Bus I/O controller
- Eight USB 2.0 devices
- One serial port
- One parallel port
- Four Serial ATA interfaces
- One Parallel ATA IDE interface with UDMA 33, ATA-66/100 support
- One diskette drive interface
- PS/2* keyboard and mouse ports
- 10/100 Mb/sec LAN subsystem
- PCI Conventional bus connectors (four on the D915GAV; two on the D915GAG)
- PCI Express x1 bus add-in card connectors (two on the D915GAV; one on the D915GAG)
- One PCI Express x16 bus add-in card connector (both boards)
Hope this helps,
