Intel® Desktop Boards
Peer-to-peer support only
11476 Discussions
Enable wake-on-lan on DG41WV motherboard
LBert7
Hello.
What options do i have to enable (or disable) on the BIOS and in the advanced LANboard options for make the wake-on-lan functionality work ?
Silvia_L_Intel1
Hello Azertix,
The options available for the "Wake on LAN" feature depend on which Operating system you are using.
On BIOS, under the "Power Tab", the setting "wake on LAN from S4/S5 needs to be power on- normal boot.
Something very important is that the setting "Deep S4/S5 needs to be disable.
Then, Network needs to be the first boot device priority on the BIOS.
The BIOS version needs to be update to the latest one. https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Intel%20Desktop%20Board%20dg41wv https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Intel%20Desktop%20Board%20dg41wv
The Network's drivers also need to be update. This link provides all drivers and they one customer needs will be downloaded automatically. http://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22283 http://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22283
You would need to unzip the file to any specific folder and run AUTORUN.EXE file and select install (drivers and software), driver will install without any problem.
Regards.
LBert7
Hello Sylvia.
Thank you for this helpfull informations. i will try this tomorrow...
LBert7
Hello.
I finally found the solution.
I just talked about "Stop LAN wake up" option. This is my english traduction from french ("Arrêter Réveil par réseau").
And i think it already was a (bad) traduction from english to french (by computer engineers).
So it appears that this option finally needs to be enabled !
After, i did some tests and the result is :
- "Boot to network" can be disabled (it automatically removes Ethernet from the boot list)
- "Wake system from S5" can be disabled
The only option required in the BIOS is set "Wake on LAN from S5" to "Power on".
2 options must be checked in the advanced LANboard parameters (Realtek PCIe GBE Family Controller) :
- "Stop LAN wake up" (="Arrêter Réveil par réseau") => "Enable" (="Activer")
- "LAN Wake up functions" (="Fonctions Réveil par le réseau") => "Magic Packet" (="Paquet Magic")
I hope this informations will be usefull for other users...
Bye,
Azertix
Silvia_L_Intel1
Thanks a lot for the information provided.
Regards.
LBert7
Hello Sylvia.
I just installed last BIOS version and LAN drivers (i don't have intel LANboard, it's Realtek).
Then, i looked the BIOS wake-on-lan options and no new options appears.
Wake on LAN from S5 is set to "Power on".
I don't have any "Deep S4/S5" option.
I put "Ethernet" to first boot device.
No change on the LANboard advanced parameters :
Stop LAN wake up : Disabled
LAN wake up functions : Magic Packet
No change : wake-on-lan does'nt work
