Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11360 Discussions
Error 12 Windows XP - No free resources.........
RSteg
Dear fellows,
I just purchased a DH61WW motherboard, but i´m facing a strange problem.
I´m not able to install de Gameport on a C media 8738 pci sound card (yes I know its very old stuff), due to error 12 on windows XP Pro
actions so far
1 - Tried diferrent drive versions
2 - reinstall WIndows XP
3 - reinstall MB drivrers
4 - Install a Sound card with different chipset (ESS)
5 - BIOS upgrades (latest version available)
But no luck.
Any ideas..
best regards
AlHill
Unsupported board with unsupported OS. Three years now since XP support was ended by Microsoft. If anyone could help, it would be Microsoft as this is a driver issue on XP. And, Microsoft will not help.
I would try posting in https://answers.microsoft.com/en-us/windows https://answers.microsoft.com/en-us/windows
However, I am certain you will get the same result there.
Doc
n_scott_pearson
Super User Retired Employee
On "modern" motherboards, there is no support for PCI built into the chipset. The motherboards that do provide PCI slots do so using bridge I/Cs. There are many PCI devices and device capabilities that do not work well in these slots. I am speculating that this is one of those cases. Your best bet for adding a joystick/gamepad is to look for one that has a USB interface.
Hope this helps,
Community Manager
Thank you Al Hill and N. Scott Pearson for your contribution.
rstega, in this case, the best option is to follow the recommendations provided by Al and Scott.
Please don't hesitate in replying to this post in case you need further assistance.
Juan Carlos
RSteg
Dear Fellows.
I´d like to thanks your fast answers.
It´s right that is a matter of compatibility, once everything was fine with my older MB (ASUS, dual core)
I´m very sad to give up on my old Microsoft sidewinder...
best regards
n_scott_pearson
Don't give it up; get one of these (less that US$8) - https://www.amazon.com/Belkin-F3U200-08INCH-Joystick-Adapter-SideWinder/dp/B000067RIV Amazon.com: Belkin USB Joystick Adapter for SideWinder
Community Manager
Hello rstega,
I was reviewing this thread and I wanted to know if you need further assistance?
Please don't hesitate in replying to this post if you have additional questions.
Juan Carlos
RSteg
Hello All.
We can close this case, once I bought a new usb game controller.
I bought an USB -> gameport adaptor, but does not work with my MS Sidewinder FFB Whell.
Well, its time for this wonderfull controller to rest.
Thanks to all that support this thread.
regards
Community Manager
Hello rstega,
I am sorry to know it didn't work.
Please don't hesitate in contacting us back if you need further assistance.
Juan Carlos
n_scott_pearson
Too bad. The adapter is *supposed* to work with Sidewinder units. Ah well...
RSteg
It´s almost true.
These adaptors work with MS FF joystick (3D pro) if i´m not wrong.
The FFB wheel uses a special comunication protocol called OVERDRIVE (MS patent).
Thanks again for your help.
Cheers.
