Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
Error 1e en dp67bg / i5 3570k
NLope5
amigos tengo un problema con esta placa DP67BG en el led 1E que podria ser?? la pc se reinicia constatemente. las espesificaciones de mi pc para ver si tienen alguna respuesta. Placa: intel DP67BG. Ram : corsair 8gb. Procesador: i5 3570k. Fuente de poder: 850Wcorsair. Video Nvidia Edga: GTX 550TI ayuda por favor todo esto es nuevo de caja.
n_scott_pearson
Super User Retired Employee
Please describe what is happening in more detail. What do you mean by "LED 1E"?
If the board is cycling on and off, try unplugging power and the remove the CR2032 battery from the board for 15 minutes.
n_scott_pearson
Wait, do you mean that you are seeing POST code 1E on the two-character display? This code means that the last thing that the board attempted to do was detect what DRAM was present. If it is power cycling at this point, then it is an indication that it did not see any memory. This could be an indication of bad DIMMs or it could be an indication of a failed component on the board or perhaps even within the processor.
