Intel® Desktop Boards
Peer-to-peer support only
11476 Discussions
Error Intel Rapid Storage Technology : RAID1 Error Occured on Physical Devices
MMBAR
Hi everybody,
I have an IBM x series and when i try to boot it shows me this message.
Please can anyone tell me what is the cause and how can resolve the problem.
Regards.
Kevin_M_Intel
Hello moha037,
When getting Raid Status failed most of times it is necessary to reestablish the volume since the structure failed. I see you have a raid 1 so you can try setting the System to non raid from CTRL-I.
You are going to get a notification that all information will be lost but on RAID 1 this does not apply. You can set it to non raid and all information will be on both HDD and you should be able to boot into the HDD without a problem.
Kevin M
