Intel® Desktop Boards
Peer-to-peer support only
11428 Discussions
Existe forma de medir el vcore con un multimetro?
WRome
Es posible medir el vcore de la placa madre dc55hc con un multimetro?
Miguel_C_Old
Hi Welbin,
Processor voltage is low, it is under 1.5 volts and Vcores voltages are equal or less. The processor has 1156 pins on the bottom in contact with the motherboard. If you want to get Vcore, it is necessary to use a program (software). It could be a third party software such as CPU-Z
Mike C
