Intel® Desktop Boards
Peer-to-peer support only
11480 Discussions
Experience with SeaTools
diablo_692
Has anyone out there been able to successfully use SeaTools to view and test their HDDs when they're attached to the ICH10R? I'm running WIn 7 Pro x64 on a DX58SO with the latest BIOS and drivers, and I can't get SeaTools for Windows to run a test although it can see both drives. SeaTools for DOS (which is supposed to be a better choice when compatibility issues are suspected) won't even detect the HDDs attached to the ICH10R. The mobo BIOS is set to RAID as I'm planning to build an array in the future, but currently the one attached SSD and one conventional Seagate HDD are not in an array. Any ideas?
Community Manager
Seatools doesn't support RAID.
If you haven't set up the RAID array yet, you can change the controller mode in the BIOS setup to IDE or AHCI. Seatools should now recognize your drives. When finished, change the BIOS back. You can't do this once the array has been set up and initialized, of course, but until then it won't cause a problem.
Community Manager
diablo_692
RB, I had read elsewhere that SeaTools has issues trying to detect drives through a RAID controller, so I did as you suggested. I removed my SSD (used as my Win 7 boot drive) first, then powered back on, entered the BIOS and set SATA drives back to "IDE". I then booted from the SeaTools for DOS CD and it did indeed find the Seagate HDD. Problem now is SeaTools won't run any of the tests on the drive, they start and then just hang. That's not a problem for this forum though.
Thanks for your help.
