I procured a GAZ77-70K and I am having the worst time attempting to get it to POST. I've installed a i5 2500k, and no matter what memory I install the debug LED displays 04, then 28, and then it will restart and repeat the same process. Along with this, no video is displayed from the installed 7970.
Where should I even start?
Hello alexagc, you should test the system on a basic configuration including on board graphics and only leaving the power cables, the processor with the Heat Sink and the monitor connected.
remove the 7970 and try with the display connected to the IGP
