Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
GPU IS WORKING GPU FANS NOT WORKING
CharlesJosephEscoto
gpu is working because i can use computer, BUT the gpu fans not working (overheating as go on)
any suggestions why?
how to fix?
AlHill
If the gpu fan is not working, it means the cpu fan is not working, which is why you are overheating (there is no gpu fan).
And, since you provided no information, do this:
Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
CharlesJosephEscoto
let me make them clear >
I already said on my statement, "gpu is working because i can use computer, BUT the gpu fans not working (overheating as go on)"
here is a clip of the gpu (gpu is working when using the pc JUST ONLY the fan of it not working (not spinning) which will lead to oveheating GPU)
https://drive.google.com/file/d/1ATZB2jmPE6gCFYMJfXrF1jHMonHRA8cl/view?usp=sharing
2pins of the fan is plug into the gpu,
What can be the possible cause of this? (fix)
AlHill
Well, several problems:
  • You did not provide the ssu report.
  • Intel does not have add-on graphics adapters
  • That does not appear to be an intel desktop board
Run the ssu report as I asked so we can get the information needed.
n_scott_pearson
Super User Retired Employee
I don't need to see the SSU report. This is a pre-Core motherboard (Core 2 Duo, Core 2 Quad or something similar); pretty ancient. This is also a 3rd-party graphics card whose fan has failed. There is nothing that we can do about it.
Give the fan blades a shove and see if you can get them to spin again (might be caught against the cowling).
Get a replacement fan.
Get a replacement graphics card.
CharlesJosephEscoto
the thing about this is, that's already the replacement fan (new fan),
reason i can only think of is faulty socket (2 pins)
which i don't know if making sense, because the gpu is working
n_scott_pearson
You've wiggled the connector?
You've tried plugging it in the other way?
Are you sure that you got the right replacement fan? Some boards only provide 5V so fans that are 12V either don't spin or spin only very slowly.
CharlesJosephEscoto
the old fan is 12v and the new one is also 12v
here is the clip trying to use the old fan again (wiggling fan) https://drive.google.com/file/d/1vhh7VHfFunU6s8UzY7D0NbiGncjYMdj9/view?usp=sharing
the fan had no blockage as shown because the fan can move only if u wiggle
tried to wiggle the connector (nothing happens)
overheating while using the pc ->
https://drive.google.com/drive/folders/1_jdUPgzZ-_TfF0xvTlzGQG7jkO4PJxNf?usp=sharing
n_scott_pearson
Well, sounds like you will need to replace that graphics card. I would look for something from the same era; there are lots of compatibility issues that can crop up using something more modern.
CharlesJosephEscoto
Ok , thank you for that,
the thing i want to know now is WHY that thing happened,
any idea why? (im just curious)
like this gpu was like 2months old of use on this old pc,
and i just cleaned some of the dust and dirt, rub them, remove screws and when i plug it back its not working, like i just clean it, i did not change anything and back everything correctly
n_scott_pearson
I haven't enough information to identify what has happened. What I can say is that this is a very old system and components can get fragile with age. Your 2 month-old card is really a lot older than that.
