Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11451 Discussions
Get SRT rolling on Data Drive separate from system disk
JWalk13
Hi - first posting.
I've been digging through the forums but not quite finding what I'm looking for.
I'm running an Intel DZ68BC board with two Seagate Momentus XT drives in RAID1 for the System Drive. I do a great deal of database work w lots of I/O so I've also got a 2TB WD Black Data Drive. I'm also running an external drive (RAID1 inside of a Vantec box via eSata) but figure that is of little concern.
My big idea is to install an SSD and team it with the data drive in a SRT RAID configuration. Though I enjoy poking around w the box I'm really just an enthusiast - not a real IT guy.
Since this is not my system drive would the operation be as simple as installing the SSD, going into the Intel Rapid Storage Tech program and selecting accelerate for the data drive? One question is, since the system drives are already in a RAID, will that cause confusion to the configuration tools/chips when I want to put two other disks in a separate RAID? Here's another, would I absolutely need to update BIOS or should stock BIOS be OK?
Easy as pie? Pitfalls to know about? Fools errand?
Appreciation in advance for any thoughts/suggestions.
J
Silvia_L_Intel1
Hello JK Walker111,
If you want to accelerate one of the 2 RAID 1 you have in the system, once you access the Intel® Rapid Storage Technology you will be able to see the option.
The 2 RAIDs will appear on the software, so make sure you select the one you want to accelerate.
There should not be any partition on the SSD, in order to see the "accelerate" option on the software.
Regarding the BIOS updated, we recommend customers to have the latest BIOS version installed, however if your system is working fine, a BIOS update is not necessary.
Sylvia L
Silvia_L_Intel1
Hello JK Walker111,
Sylvia L
JWalk13
Thanks, Silvia. I'll give it a shot!
