Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
Graphic Driver Update
vaidyad
I have Intel DB85FL Board - 8GB Ram. I got a message that a driver is due for update. The details are
Description:
This download installs the Intel® Graphics Driver for 4th Gen.
Version:
x.x.x.5117
Release date:
1/10/2020
Size:
120.39 MB
While installing it says "The computer does not meet the minimum requirements for installing the software". How do I know what are the requirements, so that I may upgrade if possible.
AlHill
On these boards, it is a case of onboard or add-on, but not both.  You want to use the onboard graphics, remove your add-on card.
Doc
AlHill
What is your current bios version?
Doc
n_scott_pearson
Super User Retired Employee
And what is your processor?
vaidyad
Thanks. I have the following info about the processor.
Intel® Core™ i5-4440 CPU @ 3.10GHz
  • Device Details
  • ManufacturerGenuineIntel
  • DescriptionIntel64 Family 6 Model 60 Stepping 3
  • Architecturex64
  • # of Cores4
  • Processor Base Frequency3101 MHz
  • Current Voltage1.8
  • Level 2 Cache1024 Kb
  • Level 3 Cache6144 Kb
  • Processor Id0x306C3
  • Revision15363
  • AvailabilityRunning at full power
Please let me know if that is sufficient.
AlHill
So we can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (look at the instructions under the reply window).
Doc
vaidyad
Thanks. Here is the copy.
n_scott_pearson
According to what I am seeing, the Intel processor-based graphics engine is disabled. This is perfectly normal because you have NVIDIA graphics card installed. Becsuse the engine is disabled, the driver update will fail to install. This too is normal, though I wish the installer explained this less cryptically.
vaidyad
Thanks. Will it be advisable to enable Intel processor-based graphics engine ? If it is advisable, then how to do it?
AlHill
Doc
vaidyad
Ok. Thanks a lot. Issue stands resolved, with full reasoning.
vaidyad
Thanks. I am a non-technical person. I could find the following information.
INTEL_ DB85FL__
BIOS Version - Default System BIOS
Date - 6/6/2013
Motherboard Manufacturer - Intel Corporation
Model – DB85FL – Version AAG89861-203
Operating System Edition - Microsoft Windows 7 Home Premium (64-bit)
Version (Build) Unknown
