Intel® Desktop Boards
Peer-to-peer support only
Graphics memory
BGang
how many graphics is there on DH67BL motherboard.
I have core i5-3550 3.30GHZ processor
Silvia_L_Intel1
Hello Bharat@007, the processor you are using (I5-3550) comes with HD graphics 2500. http://ark.intel.com/products/65516/Intel-Core-i5-3550-Processor-6M-Cache-up-to-3_70-GHz?q=3550 ARK | Intel&# 174; Core™ i5-3550 Processor (6M Cache, up to 3.70 GHz)
Using the DH67BL motherboard you will be able to connect a video output (TV/Monitor) through an HDMI or a DVI-I ports.
It is very important to check the compatibility between these two products, because according to the following link http://processormatch.intel.com/compdb/SearchResult.aspx?ProcNbr=i5-3550&BoardName=DH67BL&Lang=en-US Intel® Processors and Boards Compatibility Tool - Search Results Page this combination may be compatible.
The compatibility will depends on the AA number of the motherboard and the SL number of the processor.
I would recommend you to check this information first.
