Intel® Desktop Boards
Peer-to-peer support only
11435 Discussions
HD4000 Windows7 64Bit - Blackscreen
Community Manager
Hallo Guy's
i have a Intel Desktop Board DZ77GA-70K with a Intel Graphics HD4000.
Operation System: Windows7 64Bit SP1
Yesterday, i make Windows Updates and shutdown my OS.
Today i start my PC and the last i see is the Windows Bootlogo. Then i have a Blackscreen.
I connect with Remotedesktop to my PC and he runs.
In the Device Manager my Graphic Card says: Device not run Errorcode 43.
I delete the Intel Software and Driver, after i install the newest Driver.
No chance! The same Problem: Balcksreen but my OS runs over RDP.
What can I do?
Thank for Help.
Silvia_L_Intel1
Hello Ibuser,
Bear in mind the driver downloaded by the Microsoft* Windows* automatic updated is not fully compatible with this motherboard. ( we have seeing this behavior before), therefore our best recommendation is for you to perform a clean installation of the Operating system and install the latest driver from our website at :
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Deskto... http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Deskto...
We also recommended you to disable the automatic updates from Microsoft* Windows* to prevent this situation again.
iuser
Today i restart my PC.
Now i have a black screen. I didn't update my Graphic Driver. Not over Windows and not over Intel.
In the safe mode runs my Windows7 64Bit.
I reinstall my System and install the last graphic driver for my Mainboard DZ77GA-70K.
After reboot, i have a black screen.
I have make a BIOS Update an reset it. My last idea, i change my RAM.
Nothing works. Is my Mainboard broke? What can i do?
Thanks for Help
Silvia_L_Intel1
Ibuser1, Please let me know which the current BIOS version on your system is?
  • Can you also provide me the model number of your processor and video card installed?
  • Please take the system outside of the chassis. Make sure you disconnect all other components from the motherboard and take the product out in a non-conducted surface.
  • Clear the CMOS. While having all components disconnected from the motherboard, disconnect the BIOS jumper and remove the battery for about 15-20 minutes.
  • Test the system out of the chassis, minimal configuration (motherboard, processor, power supply and 1 memory stick
Please let me know the results.
Silvia_L_Intel1
We have developed a new driver. Please try it at this link.
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3712&DwnldID=23639&ProductFamily=Grap...®+Core™+Processors+with+Intel®+HD+Graphics+4000&lang=eng https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3712&DwnldID=23639&ProductFamily=Grap...®+Core™+Processors+with+Intel®+HD+Graphics+4000&lang=eng
