My motherboard is: ASRock H81M-HDS
I have Intel(r) HD Graphics 4600 and run Windows 7 64bit.
I do not appear to have any Graphics Audio Drivers and when I try to install them it says that I do not meet the minimum system requirements. This means that the TV (connected straight through an HDMI cable) is not picked up at all as an audio device.
- Tags:
- HDMI
Thanks for joining the community.
I understand there is no audio through HDMI port and you are unable to install video drivers.
At this stage, I recommend loading the latest video drivers for your graphics controller by performing manual installation; this will force the registry to take generic video drivers.
See instructions here:
http://support.intel.com/support/graphics/sb/CS-022355.htm http://support.intel.com/support/graphics/sb/CS-022355.htm
Download the zip version of the video driver:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3720&DwnldID=23714&ProductFamily=Grap... https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3720&DwnldID=23714&ProductFamily=Grap...
Allan.
After Step 10 on
http://www.intel.com/support/graphics/sb/CS-033915.htm http://www.intel.com/support/graphics/sb/CS-033915.htm
The computer tells me "The best driver software for your device is already installed"
"Windows has determined the driver software for your device is up to date"
and then only gives me the "Close" option.
So I ran the included Setup file and it ran, installed, restarted and no change.
Thanks for the information. Please copy-paste or attach the Graphics report generated within the Intel Graphics User Interface. To access this report, please click on Start >> Control Panel >>Intel GMA driver >> information >> Save To File...
http://www.intel.com/support/graphics/sb/cs-009476.htm http://www.intel.com/support/graphics/sb/cs-009476.htm
Allan.
Here you go:
Intel(R) HD Graphics 4600
Report Date: Thursday, May 08, 2014
Report Time [hh:mm:ss]: 5:50:43 AM
Driver Version: 10.18.10.3496
Operating System: Windows* 7 Professional(6.1.7601)
Default Language: English (New Zealand)
Installed DirectX* Version: 11.0
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.2
OpenCL* Version: 1.2
Physical Memory: 7864 MB
Processor: Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz
Processor Speed: 3099 MHz
Vendor ID: 8086
Device ID: 0412
Device Revision: 06
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4600
Video BIOS: 2166.0
Current Resolution: 1280 x 800
* Devices connected to the Graphics Accelerator *
Active Displays: 2
* Monitor *
Display Type: Analog
Serial Number: ACRad52
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: VGA
Device Type: Monitor
Maximum Image Size
Horizontal Size: 16.14 inches
Vertical Size: 10.24 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (67p Hz)
640 x 480 (72p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
800 x 600 (56p Hz)
800 x 600 (60p Hz)
800 x 600 (72p Hz)
800 x 600 (75p Hz)
832 x 624 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (70p Hz)
1024 x 768 (75p Hz)
1152 x 864 (75p Hz)
1280 x 1024 (75p Hz)
1280 x 1024 (60p Hz)
1280 x 960 (60p Hz)
1440 x 900 (59p Hz)
1440 x 900 (60p Hz)
Power Management Support
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 04 72 52 AD 1E 0F 00 73
1E 11 01 03 68 29 1A 78 2E 4F A5 A4 59 49 99 24
12 50 54 BF EF 00 81 80 81 40 71 4F 95 00 01 01
01 01 01 01 01 01 9A 29 A0 D0 51 84 22 30 50 98
36 00 98 FF 10 00 00 1C 00 00 00 FD 00 38 4C 1E
52 0E 00 0A 20 20 20 20 20 20 00 00 00 FC 00 41
63 65 72 20 41 4C 31 39 31 36 57 0A 00 00 00 FF
00 4C 35 32 30 39 31 35 38 36 33 35 31 0A 00 07
* Digital Television *
Display Type: Digital
Serial Number: AAA0000
Gamma: 1
Connector Type: HDMI
Device Type: Digital Television
Supported Modes
640 x 480 (60p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
720 x 576 (50i Hz)
720 x 576 (50p Hz)
720 x 480 (60i Hz)
720 x 480 (60p Hz)
720 x 480 (59p Hz)
800 x 600 (75p Hz)
800 x 600 (60p Hz)
1024 x 768 (70p Hz)
1024 x 768 (60p Hz)
1024 x 768 (75p Hz)
1280 x 720 (60p Hz)
1280 x 720 (50p Hz)
1360 x 768 (60p Hz)
1920 x 1080 (60p Hz)
1920 x 1080 (24p Hz)
1920 x 1080 (50p Hz)
1920 x 1080 (50i Hz)
1920 x 1080 (60i Hz)
Standby Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 04 21 00 00 00 00 00 00
06 16 01 03 80 00 00 00 8A EE 95 A3 54 4C 99 26
0F 50 54 A5 4E 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 66 21 50 B0 51 00 1B 30 40 70
36 00 3F 43 21 00 00 1E 00 00 00 FD 00 18 55 0F
50 10 00 0A 20 20 20 20 20 20 00 00 00 FC 00 56
45 4F 4E 2D 54 56 0A 20 20 20 20 20 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 59
02 03 24 74 50 90 05 04 03 07 02 06 01 1F 14 13
12 16 11 15 20 23 09 07 03 83 01 00 00 66 03 0C
00 20 00 80 01 1D 00 BC 52 D0 1E 20 B8 28 55 40
C4 8E 21 00 00 1E 01 1D 80 D0 72 1C 16 20 10 2C
25 80 C4 8E 21 00 00 9E 8C 0A D0 8A 20 E0 2D 10
10 3E 96 00 13 8E 21 00 00 18 8C 0A D0 90 20 40
31 20 0C 40 55 00 13 8E 21 00 00 18 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 73
* Other names and brands are the property of their respective owners.
This issue has been solved, I got bored and explored the BIOS and found a setting that was disabling the HDMI Audio.
Thanks for sharing the results; I am glad your computer is working again.
Allan.
