Intel® Desktop Boards
Peer-to-peer support only
11480 Discussions
HDMI audio for dn2800mt running windows xp
Community Manager
For the board dn2800mt running windows xp, I can't seem to install a driver for "audio device on high-definition audio bus", consequently there is no audio on the HDMI port. I downloaded and ran the file AUD_XP_5.10.0.6710_PV.exe, which successfully completed, but the device manager still indicates that the driver was not installed. Is there something else that needs to be done to install this driver or is there s different driver available that will work?
dson2
I am having the same problem, did u find a solution.. But when i connect the D-sub pin i can get the sound via the audio output....whyis thgis happening
Silvia_L_Intel1
Thank you for posting,
You may check the list of operating systems supported in the following article:
http://www.intel.com/support/motherboards/desktop/sb/cs-008326.htm http://www.intel.com/support/motherboards/desktop/sb/cs-008326.htm
Some desktop boards include features that are supported only under certain operating systems. All board features (audio, video, LAN, etc.) may not be supported and Intel is not planning on making drivers for this specific OS.
Regards.
dson2
why is the INTEL CENTRINO WIRELSS N 1030 HALF MINI PCI-E ADAPTER NOT WORKING ON INTEL DN2800MT DESKTOP BOARD..TRIED EVERYTHING
Silvia_L_Intel1
Deep84, please open a new community thread in the Intel(R) Wireless forum for this information as this does not relate to the original topic. /community/tech/wireless http://communities.intel.com/community/tech/wireless
