Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11360 Discussions
HDMI problems with DH55TC
MSoma
I have Intel DH55TC motherboard. It has HDMI so thought of using my LCD and LED TV for display. I plugged the HDMI cable into SOny BRavia 40EX400. It showed screen for few times and then it started showing no signal.
Recently, I used Samsung 22F5100 LED TV and tried plugging PC into HDMI/DVI port on TV using HDMI-HDMI cable, also tried DVI-HDMI cable to connect from DVI port on board. Lastly I also tried VGA_HDMI connectivity but no luck.
My Laptop, Tablet, Xbox all work on both these TVs seamlessly without doing any thing.
Just to clear the last doubt, I upgraded all the drivers of the board but turned out to be of no use.
Can any one help me, as to what could be the problem.
Allan_J_Intel1
Thanks for joining the desktop community.
I understand you are experiencing HDMI issues. The monitor is not detected.
At this point, let's make sure you have updated BIOS on the computer:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=20725&lang=eng Intel® Download Center
File name: TCIBX10H.86A.0048.EB.EXE
Also, check some troubleshooting tips about HDMI issue here: http://www.intel.com/support/graphics/sb/CS-034397.htm Graphics Drivers — HDMI Technology FAQ
Allan.
MSoma
tried upgrading the flash. no luck. On my sony 40EX400 LCD full HD tv it shows the msg as unsupported signal. I am going through the FAQs but find it extremely hard to believe that you have to take so many twists and turns to get to it.
It should be just plug n play.
Any clues.
Allan_J_Intel1
Thanks for the update.
Please make sure get the latest video drivers here:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProdId=3231 Intel® Download Center
Filter by operating system and try to install the driver when it finishes downloading, to verify that your system will accept it.
Allan.
