Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
HELP!! - A bootable device has not been detected & Windows Boot Manager ????
DBrem
Hi Guys,
We have multiple Intel® Desktop Board DP67BG, but a lot of them won't boot anything!
I get the following warning when I start the pc:
When you look in the bios I can see the hard drive.
When I use F10(Boot menu) and than select the hard drive, than will windows boot. Otherwise it won't boot.
I already tried diffrent bios version, diffrents hard drives , but this problems keeps comming back.
Sometimes it helps to but the hard drive in IDE mode and than it works.
But that doesn't even work.
When I press F10 I see Windows Boot Manager, can someone tell me what that is?
I hope someone can help me.
Dirk
Silvia_L_Intel1
Hello Dirk thanks for joining the Intel Community.
Would you please know in how many systems are you experiencing this behavior? Which is the current BIOS version installed?
Would you please send me the system information? Please type "msinfo32" under search and send me the information you get?
Also, can you run the System Identification Utility and provide the code given by the software?
http://www.intel.com/support/siu.htm http://www.intel.com/support/siu.htm
