Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
Hardware prefetcher disable option on DQ87PG
BGoel
I want to disable L2 hardware prefetcher on DQ87PG motherboard but I don't see that option in BIOS. Can someone tell me if there is any other way to disable the prefetcher? I have Haswell chip (Core i7 4770) on this board.
Allan_J_Intel1
Thanks for joining the Desktop Board community.
I understand you are looking for a way to disable hardware prefetch feature.
I have found some forums mentioning how to disable this feature and they all talk about entering BIOS and disable it through any CPU tab configuration.
I regret to inform you that the motherboard model DQ87PG does not provide any option at BIOS level that helps enabling or disabling such feature.
Intel suggests you keep checking this post for any other community member that has experienced same issue and provide solutions to your request.
Allan.
