Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
Has anyone built a system based on the DH61AG board in the IN-WIN K1?
The IN-WIN K1 case arrived today without any documentation.
This case, the DH61AG board, the core i5 2405s processor, and the INTEL BXHTS1155LP thermal solution constituted the ITC 2011 SFF desktop offer.
Highlighted
Community Manager
The only question I really have is assembling the board and thermal solution in the case. It's not really intuitive (at least not to me).
Thanks in advance for any help.
Highlighted
I am working on this combo. But there was a problem to power on the system.
You need to remove the plate from the heatsink and put on the back of the MB.
Then you can mount the heat contact with heat pipe on the top of MB.
At first mount the heat sink then put them into the case.
Look at the manual you can know what I said.
Goog luck
Highlighted
Community Manager
I'm having a problem with this combo. Not the physical install, but it won't power on at all (http://communities.intel.com/message/151849# 151849 http://communities.intel.com/message/151849# 151849).
Highlighted
In-Win K1 also missed a power switch pad inside the case in the system. So I can not push the power button to turn on when I seal the case. I can pull the cover of the case a little bit then the switch tip can touch the button.
