Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11460 Discussions
Have a beeping problem with new ram memory - 4gb.
pding3
beeping , and no display.
Mother board: https://www-ssl.intel.com/content/www/us/en/motherboards/desktop-motherboards/desktop-board-dg41wv.h... https://www-ssl.intel.com/content/www/us/en/motherboards/desktop-motherb...
According to this, my destop board could accept memory stick, but pratically not.
Ram sticks : http://www.kingston.com/dataSheets/KVR13n9s8_4.pdf http://www.kingston.com/dataSheets/KVR13n9s8_4.pdf
I have two of these rams and both news. I dont think they are broken.
I just put one in A place , not two in A and B place , because in information was written max - 4gb.
Now pc working with 2x1gb ram sticks. 1333 Mhz Memory default (5-5-5-15)
Any suggestions,questions or solutions of problem?
Someone has write that:
"And you are right, it supports DDR3-1066/800 - not 1333
It was just a pure chance that your 1 GB 1333 MHz modules worked - sometimes higher frequency RAM will downclock and run - that does not mean that all 2 GB 1333 MHz should work. This is why you are hearing the beep and having other problems.
Please change over to either 1033 or 800 MHz RAM per Intel board specs. Then you can use 2 x 2 GB modules for a total of 4 GBs.""
It can be or not? Please help.
Link of system information : http://www.part.lt/img/dc78ed4d21b6073271dff9d7a7ab5c9f373.jpg http://www.part.lt/img/dc78ed4d21b6073271dff9d7a7ab5c9f373.jpg
Allan_J_Intel1
Thanks for joining the community.
I understand you are installing 1333 MHz memory on your DG41WV.
The fact that one stick of RAM is running on the system is because the BIOS is down clocking memory timing, but it will not work on all memory banks. See the link below for memory information:
http://www.intel.com/support/motherboards/desktop/dg41wv/sb/CS-031413.htm http://www.intel.com/support/motherboards/desktop/dg41wv/sb/CS-031413.htm
Allan.
