Intel® Desktop Boards
Peer-to-peer support only
11429 Discussions
Hello, I am really stuck with fast boot always enabled on my discontinued DB75en Intel motherboard. How do I disable fast boot on this particular board and get back in the bios?
BStPi1
I tried the 3 second power on button press and all the keys pressed F2 F3 F10 and F12. This is a nightmare. I'm about to pull out the battery alltogether, but that won't tell me how to get back into bios without opening the case. Anyone know this board?
LeonWaksman
  1. Install the Configuration Jumper (see section 2.3 in the Technical Product Specification https://www.intel.com/content/dam/support/us/en/documents/motherboards/desktop/db75en/db75en_techpro...) between pins (2-3).
  2. Power your PC and once you see the Configuration Menu, press F9 to set Bios to default settings. Press F10 to save the current settings.
  3. Restore the jumper to Normal position (1-2)
Leon
