Intel® Desktop Boards
Peer-to-peer support only
11479 Discussions
Hello, Intel! I have motherboard with B360 chipset. Unfortunately, USB in Windows 7 doesn't work. Could you give me drivers? Windows 7 is supported until 2020! Best wishes.
AMar0
AlHill
Windows 7 is supported until 2020, but not on your processor. Only Windows 10 is supported on 7th gen and later processors.
Doc
AMar0
Good joke from Intel, thanks!
AlHill
Check your motherboard manufacturer. They also do not support Windows 7 on your board, which is why you will find no drivers for windows 7 from them as well.
Doc
AMar0
Thanks, Al.Hill!
I've successfully installed Win7, everything works well, except USB. It means that I need only USB 3.1 driver for B360 chipset.
I understand you, there is no questions anymore.
AlHill
You did not successfully install windows 7, else you would not be here. Did you find ANY drivers for Windows 7 listed on your motherboard manufacturer's site? The answer is no, you did not.
Again, only windows 10 is supported on 7th gen and later processors. This is a Microsoft issue: https://support.microsoft.com/en-us/help/4012982/the-processor-is-not-supported-together-with-the-wi...
You carefully avoided providing your motherboard model number and processor model number, knowing this was the case.
Purchase a Windows 10 key, or use your Windows 7 key for a Windows 10 install, and avoid all the future problems. I suspect you will continue to try and use Windows 7 past January 2020. Why waste the time and effort? If you want to run WIndows 7, install Windows 10, turn on Huper-V, and then install WIndows 7 as a VM on WIndows 10.
Doc
AMar0
I do not want to avoid carefully providing my motherboard model. Please, understand me, may users use that they want to use?
I have all-in-one PC with Intel i5 8250 processor, I do not know motherboard model. I have all-in-one PCs with i5 6200, i5 7200 - they work with W7 without any plroblem. I did not know, that there is such problem with i5 8250, when I was buying new PC.
Win7 works fine but only by TeamViewer, because keyboard and mouse do not work.
I need to use W7 because I have special hardware and software and it doesn't work in W10. That's all.
AlHill
"I need to use W7 because I have special hardware and software and it doesn't work in W10. "
And, will this special hardware and software be corrected by 2020?
Upgrade the special hardware and software, or use your i5-6200.
Doc
AMar0
Al.Hill, I understand you, thanks for rapid answers! I'll change PC.
AlHill
Glad to help.
Doc
