Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
Hello and good day to all! I am in possession of Intel Desktop board DQ77MK labelled as PEGATRON v1.04 and in need for the latest BIOS update. Could you, please, post a proper BIO file, which could be used to update this board via F7 method?
A1Handy
I have been searching other web resources and found something that may be it, but I don't trust it and don't want to ruin the board.
AlHill
I am skeptical that you have a DQ77MK board labelled as Pegatron. Provide the AA number on the board to verify.
However, as you requested, here is the information and file you wanted.
The RELEASE NOTES can be found here:
https://web.archive.org/web/20191119130950/https://downloadcenter.intel.com/download/28297/BIOS-Upda...
The latest BIOS is 0074. I have attached it as a zip file:
Doc
A1Handy
Thank you Al.Hill. It worked great and now is the latest and greatest revision. I love VISUAL BIOS appearance and setup options. Used recovery method to flash, as, for some reason, other options have failed.
Your skepticism may have grounds, as I have more than one DQ77MK boards, and some of them say PEGATRON, others INTEL DESKTOP.... but, essentially they are all the same.
Perfect!
