Hello guys i have motherboards DH67GD now i use i3-2120, today i install the i5-3470 but when i run the pc i have communicate "this cpu intel management 7x need to upgrade to 8x." Please you can help me ?
With the i3-2120 installed, what bios do you have?
We need to get you to at least 0150 so you can use the i5-3470.
Doc
I have 160 Bios, whitch Bios I need update ? You can give me A link
If you have bios 0160 INSTALLED already, you should be ok.
The latest bios I have is 0163, which I have attached.
Release Notes can be found here:
It looks like the transistion to support 3rd gen processors happend with bios release 0151, so you should be OK.
I would install 0163, using the recovery method defined by Scott. Follow it exactly, do not skip or omit any steps. Do this with your i3-2120 installed. Once done successfully, install your i5-3470,
Doc
Yea but intel management still 7x version...and i5 need 8x
How update intel management to 8x
after bios update to 0163 with recovery method its working ! bios updated to 0163 and intel management to 8x thank you very mouch <3
Glad to help.
Doc
