Hi I've just joined the forum and request some help with an issue I'm having with this motherboard.
I've almost completed building a system using the following components:
Intel DQ77KB
Intel i5-3470s
G.skill 8gb ddr3 1333mhz
Samsung 840 120gb SSD
Samsung SH-224 DVD Writer
PA-1181-02XX 180w 19V Power adapter ( as recommended in the Intel thin Mini-ITX Component Catalogue 1H,2013)
Lian Li PC-Q11B Case.
As I'm still building the PC, I'm constantly in and out of the case and sometimes have to unplug all the cable including the power cable.
Unfortunately when I reconnect the power cable the PC immediately turns on (without me having touched the power button) with one of the following messages:
The following are warnings that were detected during this boot.
These can be viewed in setup on the events log page.
Warning : CMOS Battery Failure
OR
Warning : CMOS Checksum Error
Warning : CMOS Time Not Set
The end result is that the bios is reset and the time reverts to it factory defaults. All settings are lost.
My biggest concern is that the AMT vPro settings which I've painstakingly input for remote KVM will be lost in the event the client accidently turns the power switch off or if there is a general power failure.
Once I've reset all bios settings and as long as the power cable isn't removed everything is fine, the PC boots up and shuts down as expected.
Please help!
Any ideas what could be causing this problem?
Chima Madujibeya
Hi Sauac,
Based on the description you gave us, could you please try the following:
1. Disable the Wake-On-LAN option in the BIOS, maybe at the time you connect the motherboard
2. Try to update the BIOS of the motherboard you have, access the following link Download Center
Please let us know if it solves the problem.
Hi Ruben, thanks for the reply.
I've already updated the bios to the latest one which was 0051 and I had already tried disabling every single power option option that could potentially wake up the pc.
I called Intel technical support this morning and they were unable to shed any light on this issue so I sent the board back to the retailer and bought a new one while they sort out the RMA.
I'll let you know if the problem persists when I install the new board.
I returned the motherboard to the retailer and bought a new one which has resolved the issue.
