Intel® Desktop Boards
Peer-to-peer support only
11435 Discussions
Help. Trying to set up a raid 10 volume greater than 2tb
Community Manager
Hi there,
Trying to set up a raid 10 volume. I have (4) 2tb hard drives with windows 7 64bit installed on the drive I want to expand. Using Matrix Storage I am limited to creating a 2tb volume. The mother board is an Asus P6T SE. The boot drive is set as MBR. Some questions:
Is Intel Rapid Storage Technology able to run on Windows 7 64 bit (When I go through the download section it isn't available for 64bit and wouldn't install if I tried (driver was unable to install) but when I use the auto update detect it recommends RST (but still won't install)
If I can change all the drives to GPT will that solve it?
If so, can I clone an MBR drive to a GPT drive and maintain GPT?
Thanks in advance, I am pulling my hair out.10
Community Manager
Hello Jason,
To obtain further assistance on your original inquiry please contact our chipset support group:
http://www.intel.com/p/en_US/support/contactsupport Contact Support
You can also contact Asus* directly for assistance on this matter.
