Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Help with doubt ,RAM & GA-Z77-D3H mobo
Hello .. Im building a new pc for work ..
Im buying this motherboard Gigabyte GA-Z77X-D3H , I already have 2 sticks of 4 GB each one they are:
Corsair CMZ8GX3M2A1600C9 8GB 2x4GB DDR3 Vengeance 1600MHZ 1.5V XMP RAM CAS9
and I want ( or at least my idea is ..) to install other 2 sticks of 8 GB each one
Corsair CMZ16GX3M2A1600C10 16GB 2x8GB DDR3 Vengeance 1600MHZ 1.5V XMP RAM CAS10
both memorys are 1600 mhz , both are :1.5V the only difference is that one is ¨CAS9¨ and the other ¨CAS10¨
my idea is to put them this way ,in order to make them work in dual channel (?) : 4-8-4-8 =24gb of ram ?
my doubt mixing 4 and 8 gb sticks .. I would get dual channel ? or is not good,,its a waste of money, and better get another couple of 4gb to make 4-4-4-4 .. ? any help would be very appreciated!
thanks in advance
Community Manager
Yes, they'll work. The faster RAM (CAS9) will default to the slower RAM (CAS10). If you have both color coded memory slots occupied it will run in dual channel.
Community Manager
Thank you Major A! .. so if I fill all the slots : 4-8-4-8 ,it would deliver me 24gb of ram ..
ok Im sure now , correct me if Im wrong , but I was afraid that if I fill them whit 4gb for the first slot this would downgrade or lower the 8gb performance ....
and yeap giga z77 dh3 it has blue-white-blue-white slots
Community Manager
It will work. Typing this on a computer running 2 different sets of DDR2 800 (2x1GB Elpida and 2x2GB A-Data). Working just fine and has been for a while now. Did something similar with my old C2Q 9550 machine, had 2 different OCZ kits running fine. The only tid bit of advice to help ensure stability is to run the slower kit in the slot 1 and 3. Then the faster stuff in slot 2 and 4.
Here's a screenshot of my mismatched RAM in CPU-Z.
