Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
Help
Community Manager
Hi, I bought Intel DG43RK Board and added it to my PC with processor Dual Cor 2.8 GHZ. It was working fine with all components until recently. Then one day PSU failed. The earlier PSU was 400 w. I borrowed from my friend his 600 w PSU which worked perfectly.Yesterday I bought 650 W PSU and installed. My system does not boot up. When I switch on power Heat sink fan runs and then power trip for 10 secs then Heat Sink Fan starts running but there is not boot up beeps but fan keeps running. Please help me.
Community Manager
Hello goraadami,
Try clearing the CMOS by removing the 2 power cables and the CMOS battery for 30 minutes and test with the 600w power supply again to check if it will boot up again.
Regards.
Community Manager
Hello goraadami,
Regards.
Community Manager
Halo Mr. Victor,
Thanx for reply. I'll do the suggestion and let you know as the machine is at my home.
