Intel® Desktop Boards
Peer-to-peer support only
11479 Discussions
Hi I have an intel DH61WW motherboard and it does not let me boot into the bios which is at version 0113.
User1590405493623164
AlHill
More information needed.
Does it boot to the OS?
Any lights flashing? Any fans spinning? Anything on the screen?
Did it just start doing this?
Provide as much information as you can.
Doc
Yes it does boot to the os and the computer runs normally. All the fans spin and there are no light on it that you have to press f2 to open the bios but it does not open otherwise the pc runs normally. I bought the PC a few days ago and it did this since I bought it.
n_scott_pearson
Super User Retired Employee
So you are just not able to press F2 and get into BIOS Setup? If this is the case, it could be because the previous owner enabled Fast Boot. You can fix this by,
  1. Power off.
  2. Move the (yellow) BIOS Configuration jumper from the pins 1-2 to pins 2-3.
  3. Power on.
  4. You should be taken into BIOS Setup automatically.
  5. Press F9 (followed by Y) to reset the BIOS configuration.
  6. Press F10 (followed by Y) to save this configuration and exit.
  7. When you see the BIOS Splash screen, power off.
  8. Return the BIOS Configuration jumper to pins 1-2.
  9. Power on.
When you see the BIOS Splash Screen, you should be able to press F2 (press it a couple of times) and get into BIOS Setup.
n_scott_pearson
Once everything seems ok, you should update to the latest BIOS. I have attached a ZIP file that contains the latest BIOS (you won't need the other files in this ZIP). Use the F7 method to install this update.
