Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
Hi i have a dx58so board, now really slow load up
sorry to trouble you, but i need help with my board. when i first bought it the bot up was satisfactory, around 10 sec until the splash screen and another 20 seconds until the windows loading screen starts. now even before the splash screen begins it takes 2-3 minutes and afterwards another 2-3 minutes until the windows load screen.
although i never questioned it before i really do find the boot screen of quite odd. i am used to a boot up with plenty of numbers and stuff. with intel its just black with a blinking underscore at the top left, then followed by the splash screen, there are also weird codes at the bottom left, e7, eb_, 5a, ba. then there is this marvell thing at it states that no hard drive found on the first drive, eventually it will load up. it does recognize all my drives without any problems. but does it have to take this slow... i mean my old pentium 4 computer boots faster than this. please help. i want to know if there is a problem with my board.
Highlighted
This board has indeed a strange boot sequence.
The marvell chip looks for connected external drives if they are connected to the E-Sata ports.
I'm not using my computer at the moment but look in the BIOS if you can turn the marvell off if you don't have any external drives.
The "weird codes" are BIOS post codes, they help in case the board kan not boot up , so at which boot stage the problem is located.
The blinking underscore is indeed a strange way.
If it is supposed to hide bios messages, BIOS manufacturers have still no idea how to deal with this.
Cause, a modern OS does not need the BIOS to run.
So, it would be great that the user can switch off the BIOS and by doing that, enable a simple boot loader with minor error trapping.
if the board can not boot , then an automatic reboot with enable BIOS again.
Or switching between full BIOS and simple boot loader via one of the function keys.
And external drives, for those that don't use it, that it can be disabled in the BIOS, well, the marvell should be part of the simple boot loader.
Conclusion : Your board runs fine, the DX58SO is known for a slower boot due too initial load times.
Highlighted
Community Manager
Have you updated the BIOS with the latest?
Checked your drive(s) for errors?
Loaded optimized defaults for BIOS?
I really like this board, I find it boots quickly, and is easy to OC from BIOS.
(It has taken me 4-5 slow months of gradually upgrading, overclocking, setting up RAID to fully exploit all its features.)
Don't know about the codes and why/what they are there for.
When I went to build/assemble I chose what I felt were best of class quality in RAM, PSU etc and haven't been disappointed.
I have a Giga X58 I use as "test bed" and had an eVGA which I pulled.
Highlighted
Gregg,
The latest BIOS and the previous BIOS caused USB problems at boot stage in my case.
Ok, once the OS has been installed not a problem but a big problem when installing an OS that needs keyboard support for setup.
Disable the Marvell E-sata ports in the BIOS, just look for a E-sata section.
Benefit of a few seconds after the marvell chip is disabled.
Highlighted
Community Manager
How about those codes ? focus on errors that are probably pointing at why. I feel no one should be seeing more than 60 seconds.
WHY a system takes minutes is not normal, or universal, but does happen for some.
A few seconds? how about finding a few minutes? "disable Marvel." Well, I've had no problem, haven't disabled, and do have and use the two eSATA ports for backup drives.
As soon as it started to take 'too long' is the time to rollback drivers, go to prior restore point and take some action and find out why.
blaming BIOS may be scapegoat but I doubt it's related. Or caused the delays.
Highlighted
Community Manager
Hi, thanks for the replies. I checked it out and it was indeed the hard drive causing the problem. One of my hard drives was overheating and errors occured. i removed the offender and the boot sequence went by smoothly.
Highlighted
Valued Contributor I
A clean install is likely to cure many problems but I found that doing a system cleanup of temp files including web files (which doesn't seem to speed up page loads anyway on a newer system) fixed a slowup. This can be a problem for the history etc. if you want that. On the other hand this may have happened before a hard drive failed, I can't recall.
