Intel® Desktop Boards
Peer-to-peer support only
sAli14
i have change RAM configuration of D945GCNL from 533 Auto to user defined 667 after saving bios setting board give ram beeps but did't show display
is there any way to reset bios setting to original or factory setting?
n_scott_pearson
Super User Retired Employee
Try first moving the BIOS Configuration jumper from the 1-2 position to the 2-3 position and then power on.
It that doesn't work, unplug from wall and remove the CR2032 battery from the board. After one hour, replace the battery and plug the system back in. Power on with the BIOS Configuration jumper in the 2-3 position.
Hope this helps,
...Scott
