Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
How can I get the Integrator Toolkit for DQ67SW?
PPerc
I have just replaced my motherboard with a DQ67SW and the BIOS was changed with a company splash. I would like to change it back to the original Intel splash. On checking the BIOS it tells me that the BIOS was changed using the Intel Integrator Toolkit.
I see upon searching the internet lots of websites say they have it but I am suspicious of these sites and would like to get a copy from Intel.
n_scott_pearson
Super User Retired Employee
Once the (original) Splash Screen has been replaced by another, it is lost. You will thus need to replace the current one with something (else) of your crafting.
If you can't wait (or Intel is not forthcoming), download the package from one of the third-party sites and then verify the integrity of the ITK_5.0.4.575.MSI installation file. Its size should be 12,409,856 bytes. Its MD5 checksum should be 08479563A8B7F6CDCCB59DB2C9F0FECE, its SHA1 checksum should be 963A8F5B0F2C0A1DD8F2A8A74E909A503F7C28A8 and its SHA-256 checksum should be D7A3F7EB9AC6D38CC5F52A3BBD673D37EE446EF4B376D292FA523EE6C424FF92.
Hope this helps,
PPerc
Thank you for the information it is very helpful.
It certainly does help.
Percival
Community Manager
Hello KenH:
In regard to your inquiry, as an option you can try to do a BIOS update on the board, to the latest version, since it is a new BIOS installation that might change it back to the original Intel splash screen.
Here is the link to do the BIOS update with the F7 method:
http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000005724.html http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000005724.html
And this is the ,BIO file you need to do it:
https://downloadcenter.intel.com/download/23750/BIOS-Update-SWQ6710H-86A- https://downloadcenter.intel.com/download/23750/BIOS-Update-SWQ6710H-86A-
I sent you a private message, please let me know if you receive it.
Alberto
n_scott_pearson
No, this will not work. The splash screen is designed to be persistent, across BIOS updates regardless of type (even doing BIOS Recovery).
PPerc
Hello Alberto,
I thank you for the information and I can tell you that I had already tried the BIOS update routine but the results were negative. The splash remained the same.
I have updated my profile here and sent you an email with the information you requested. I am afraid seeing I am now retired the information is sparse.
It would seem that the only way that will work is to somehow install the Intel Integrator Toolkit.
Thanks for your help.
Percival
PPerc
Thanks however for trying.
Percival
Community Manager
Hello KenH:
You are welcome, I just sent you a private message.
Any questions please let know.
Alberto
